Hey all,
I am going to start the process of removing my engine next week in order to replace my rear main seal. I did something wrong with the 1 piece seal install and am going to try to use a best gasket graphite rope seal on this goaround. I know I was generous with the rtv when installing my oil pan and I just wanted to ask what Is everyone's go to approach for removing rtv from the block surface. I was thinking gas and a razor blade but I wanted some input before going that route. I also plan to use the pan reinforcement brackets (that should have been used the first time...) I plan to put the engine on the stand and pull the crank so there are no obstacles in the way of cleaning and installing a new seal. Can I assume I will have to remove or push the pistons up into the bore to easily remove the crank? My rebuilt engine has about 30 miles on it and leaked 2 quarts of oil in that short time. If I were a real Mechanic I'd be out of business by now
