Hello guys. I recently installed a new carb and electronic ignition conversion kit and took it out for a test drive. When I punched it it I had a sharp whooshing sound after letting off the gas kind of like a turbo sound from a wastegate. I am trying to figure out what it might be. Any help is appreciated. I have a 1970 Lemans Sport with a 428.
Yep, used to get that a lot with my car. That sound is your car sucking up some Toyota or Honda up the tail pipe. Just wait until you here the crackling sound at high speeds as you burn the paint right off the doors of those you just passed.
Seriously, sounds odd, but my guess might be the clutch fan if you have one? or flex fan? You have not said if this is a problem or not, or if it affects performance.
May be a vacuum port on the new carb that is not capped, at WOT vacuum goes to zero, when you let off the gas vacuum returns and may be the sound you're hearing.
Is the air filter seated properly on the new carb? Last time I took mine off, I didn't get it back on correctly. Is there a filter in the cover?
Thanks for the reply guys. I think it might be a vacuum issue. I'll double check all hookups. The air filter is on correctly I believe. Its a really odd sound. Thanks again for your input.
