Got the car back from the shop drove home no problem. Got in today fired up great went to shift wouldn't go into 2nd. Stick is in neutral won't go in any gear but when you let off clutch it's still in 1st. Under all the linkage or rods are in place clips still good. Supposed to pour tomorrow and car is broke in the street any help would be great.
Banned
Sounds like your linkage needs to be adjusted.
Pull linkage from shifter shift trans into neutral.
Put shifter into neutral line up tabs parallel using a bolt or drill bit.
Adjust rods so they slide into holes, replace washers and pins.
Test.
