I've read how they don't work really well. Mine pretty much don't work at all -- even after closing the vents on the far sides of the dash.
However, I did learn that by simply running the air conditioning -- all the windows pretty much clear up at the same time -- even the windshield and sides. You can even tilt the far side air vents toward the side windows if you want.
Of course, you can turn the heat up so you don't freeze.
Keep in mind that I'm out here in California -- so the need for heavy duty windshield de-icing/defogging isn't needed -- but did want to share the tip in case you're running into the same problem...
