How do you know if the skip shift eliminator is installed? I bought the car used and I can shift to 2nd even if that light flashes.
The 1st to 4th light comes on only when, Engine is 169 degrees or higher, vehical is traveling 15-19 mph, and you are 21% throtle or less.
So if the car will shift into second at that point, the skip shift has been installed.
unless it has been tuned out like mine. just look in the tune under the cags section or at least it was there in my ls2.
