1 - 1 of 1 Posts
I have a 1967 lemans that I converted to disk front and back. I replaced all of the components, master cylinder, brake lines, booster, front and back disks. Started by bleeding the master cylinder. Bleed all of the lines starting form pass rear, driver rear, pass front and then driver front. After bleeding the brakes have a soft pedal. I swapped out the rear bleeders with the self bleeding so that I could bleed them myself and spent hours bleeding them but still has a soft pedal. Not sure if this is part of the problem but I am seeing a lot of rotor wobble which could be causing the soft pedal and am getting a dial indicator to confirm if this is from the hub or rotor. My question in regards to the rotor wobble is if I find it is the hub how would I go about correcting this problem. Any help would be appreciated.
Thank you
1 - 1 of 1 Posts
