Hello all, I've been searching around for the fix to this problem for a bit. But haven't seem to find an answer that works for me yet. Quick overview of vehicle. Customer that I painted car for died and a friend of mine bought it. The original owner had motor build up pretty well. (Built 6 years ago and never came with proper build sheet as engine builder is now retired and sold business.) Has mild cam and a lot of comp products in engine. So sad to say not a whole lot of information about engine and trans other than I know it's a true 400 engine and turbo 400 transmission with his and her shifter.
Starts and idles fine. Revs great and hot starts fine also.
So problem is when I have engine idling I can shift it into reverse every now and then cleanly with no noise. But other times (50/50) it makes this horrid squeal/metallic noise. Sometimes it's for a quick second other times I need to get out of gear immediately. Hasn't done it in any other gear. I have taken inspection cover off and the teeth on flexplate do look like they have made contact with starter. And not in a good way. Is it possible there something with the wiring where the starter would pop in and out spuratically? Also wants to stall out when put into reverse or drive. It has tripower and I'm at the point we're only the primary carb is hooked up and all my vac lines are attached. Double checked and re checked trans fluid. Has power brakes also. And customer wants to drive it tomorrow.......... Any help would be appreciated! Thanks!
