1 - 20 of 27 Posts
I been having an issue with my steering wheel asking approx 60mph. Still doing the same after the alingment, what else to look into that could be causing it
Out of round tires as Groucho said -- although some people have said the problem is with the brake rotors. Can't imagine that to be the case, though, as that would cause pulsation under braking.
Try moving the front tires to the back -- and see if the problem changes any. If it does -- it's your rubber.
I get the same problem with my '04 M6. If I go above or below 60mph by 5-10 mph, it stops shaking. I have Exclaim UHP tires all around (the previous owner's choice, not mine). I thought it was a normal thing with the car, but if it's not please let me know.
431.0 rwhp, 391.9 rwtq
If you have an 04, alot of them were shipped with a bad batch of tires. If this is the propblem that you have you'll need to have a Hunter force balance done on them. A typical balance will not solve the problem. I had to have one done by the dealer the day I picked up the car in March 04. This problem was exactly like you stated, steering wheel shakes at 60 or 65 mph, and many cars had this problem
I am a master mechanic and work at a tire shop. I hope this information can help everyone. If your vibration is below 30 mph it is separated, above 30 it is balance. If the vibration is in the steering wheel, it is the front tires. If it is in the body or seats, it is the rear. Vibration under acceleration only is the drive shaft bolts loose(happened twice to me). Warped rotors will vibrate under braking only. An alignment issue will never cause a vibration. The alignment should be checked every 12,000 miles. I recommend purchasing a lifetime warranty alignment. A pull will not cause tire wear. It is the things you don't feel (toe and camber) that cause wear. With the high caster on these cars, I recommend rotating the tires at least every 3,000 miles. This will reduce the chances of the front tires cupping and having edge wear. It will also keep the rear tires from wearing out in the center as much. This is also a good time to check the oil level. With synthetic oil, you can loose as much as 4 quarts of oil over a 6,000 mile time frame. If anyone has any questions, feel free to email me at [email protected]
Good information....
Vibrations can also come from bad CV joints and loose or worn wheel bearings. Obviously older vehicles would be more prone to these issues...
:cheers
New tires tomorrow I'll see how it goes
Discussion Starter #10
New tires, still shakes, still pulls
Sounds like alignment. I had a 325 BMW that was notorious for it. The rotors had to be PERFECT for brake shimmy not to happen. If I set a little more camber+, the problem was much less pronounced.
Id make sure the camber, caster and toe were all in spec. MacPherson strut setups like ours have little or no camber or caster adjustment capability, leaving just toe for adjustment. In fact the GTO may have none. - Im not sure as I have not had it to the tire shop yet. You may want to install camber plates in the towers, as it is a fairly common thing to do with MacPherson suspension.
Have it checked out. You may want to do a check of the tires you bought by reading the reviews on tirerack.com. The ones you have might have a habit of tramlining, and this will make an alignment issue seem worse.
Good luck
Discussion Starter #12
Good luck
Was alignmed on last Tuesday at Pontiac dealer, before they did it it just shook, now car pulls to the right also. Going in again Thursday
Did the tire installer say anything to you about a bent or out-of-round wheel? What tires did you go with?
BTW. If the camber and caster is not adjustable as I suspect it is not, those settings may be way out and the dealer wont say a thing. Maker sure you see the numbers and that they are in spec.
Discussion Starter #14
I got the numbers before they aligned it, didnt get ones after.
Installer didnt see any problems my mom works for them so she got me a deal, not sure of tires, for what was cheap since its likely the tires will be destroyed by front end problem again or I wont keep car long
I had a problem for a while but if your sure the tires are balance. You need to torque your wheels to 55 foot pounds in a star pattern and then re-torque 95 foot pounds. Also if you don't have line locks to lock the front wheels you might want to have some press on the brakes as you are torque to lugs. Make sure the the wheel is not touching the ground when you torque. There is to much deflection in the hubs rotors to do it when the wheels are on the ground.
I noticed on my m6 06 that the tires get out of round overnight and tend to vibrate for a few miles and I also get a hardly noticeable left to right movement of the steering wheel around 60 to 65 mph I have also noticed if the front tire psi is not exactly the same on both front tires it will pull just a few psi dif. and it really can make it pull hard
Discussion Starter #17
Mine happens anytime, you cant watch it bounce around when driving it, someone on passenger seat can easly see
I would say you got a wheel that could be slightly bent sounds to me like you have tried everything but your wheels. I think I would have those checked next
KC, do you have the factory BFG T/A G-force? If so, then I'm with you on the tires flat-spotting over night. They suck.
1 - 20 of 27 Posts
