I'm a relatively new owner of a 67 GTO. There is a 6 inch "play" in the steering wheel.. Is this normal?
Also, when making a U turn, I hear funny noises under the hood. Is this normal?
Jack
no and no you need to go thru the steering system, if you are the new owner check it or have a qualified mechanic look at it, could need new ps pump, idler or pitman arm, tie rods etc. steering should be tight with no"funny noises" . Steering components wear out and need to be replaced to insure maximum performance( and safety)
Ditto. You should have between o and 1 or 2 inches of play max at the steering wheel. Common wear areas on your car : center link, idler arm, tie rod ends. Other likely worn items are A-arm bushings, both upper and lower, and ball joints. Usually the gearbox is ok. Check the rag joint where the column connects to the gearbox...sometimes these rip and give you a lot of play and clunking.
thanks
Thanks a lot. This forum is great! Now I know there is a solution. The steering box and pump have minor leaks and I'll replace them and see if this fixes the problem. If it doesn't, I'll try to find a mechanic who knows a little more about steering systems.
Thanks a lot for your help.
Jack
I know the center links on the 66' are hard to find and are not the same as other a-frames of the same year, front end rebuild kit is well worth the money for safety and handling.
