1 - 12 of 12 Posts
Hey everyone,
So, just two days ago my 69 GTO was running great. Parked it to run inside to pick up my daughter from daycare, came out and gave her hell and the engine revved but no power to the wheels. Ugh oh! Yeah, took it in today and the transmission is completely shot. They don't even recommend rebuilding it, they're recommending remilling it. This will end up costing me about $2800 for everything out the door.
I don't need to stick to stock! I don't care if I keep this original transmission since the engine isn't stock nor paint color. The one I have is only a 3 speed and honestly, I'd love a 4th gear for highway driving. Do you guys have any recommendations? Should I stick with my 3 spd or buy brand new/rebuilt? I really wish I could do a manual but I know there is alot of work there and it would basically double my cost, which I don't want to do so I think I am going to stick with an auto. Any help would be appreciated!
$2800 is very STEEP price for rebuilding a T400 with quality parts and R & R. Have had at least a dozen T400's bench built from $200-850. Higher priced ones included more hard parts than a quality stock rebuild. I'd never give up an early T400, ESP one original to a '67-71 GTO. original cores out HO or RamAir cars are very desirable. the standard performance BOPC '72-79 T400's need upgrades.
Wanting to go overdrive, a well built 200R4, converter can be done for 2K. Proper TV cable adjustment at the carburetor is critical. a performance built 200R4 is a better fit for the torque band of Pontiac V8 over a 700R4.
Jegs sells a ready-to-go TH400 for $900. JEGS Performance Products 60315 | Buy JEGS Performance Transmissions at JEGS A basic rebuild kit goes for about $70 https://www.gmtransmissionparts.com/tH400-1965-1987-banner-rebuild-kit-overhaul-high-energy-friction-module/?gclid=CIW96erwrM4CFYcehgodXtENxQ and a good Hi-Perf rebuild kit is around $230. TH400 Alto Red Eagle Deluxe Chevy Performance Transmission Rebuild Kit Level 2 | eBay
For a rebuilt/remanufactured upgrade/conversion to a 4-speed automatic with OD, torque converter, and all the required modifications to make it work, ie a complete turn key out-the-door package without any other BS excuses or add-ons, then $2800 sounds reasonable. You will have better gear ratios in the trans (better performance) and the OD for cruising.
BUT, if you wanted to do a manual (rebuilt Muncie 4-speed) conversion, it would seem the consensus on the forums is about $3000 and that will probably go up. The 5-speed goes much more and you have to modify/cut your trans tunnel UNLESS you go with the new Richmond 5-speed which I recall will fit without tunnel mods. However, expensive Richmond Gear 7020526B | Buy Richmond Super Street 5-Speed Transmissions with Overdrive at JEGS So this gives you a comparative cost.
So, MY OPINION. If you have the funds and there is no rush to get it done (whatever time frame they quoted you), then I would go with the upgrade to a modern 4-sp auto w/OD to take advantage of the benefits they offer.
For ease of installation, I'd have the TH400 rebuilt/new converter (a nice "tight" 2500 RPM stall) as it will be an easy in & out with no snags and you are driving it again. If you choose to go another route, do your research, get honest pricing for parts & labor, and save towards it and do it at a later time. I don't think the TH400/converter should be more than $800 - $1,000 with good quality parts.
I agree. $2800 is an astronomical price for a TH400 rebuild. You should be able to buy 3 complete new transmissions for that price, and then some.
The problem you're likely to run into with an OD replacement is fitment - most I'm aware of require at least some modification to the transmission tunnel in the car floor to get clearance. It's likely also to need either a new custom drive shaft or modification to the one you have. Next to that, if you've got a healthy engine, is torque handling capacity. Make sure you read the fine print there and get one that's strong enough to handle what your engine makes. None of the commonly used overdrive transmissions are going to be up to the task in pure stock form.
Guys, I appreciate all of the information you have provided!
Although a 4 speed OD is enticing, I think I am going to stick to the TH400. Ideally, I would love to keep the original TH400, but I am not going to spend $2800 to do so when I can buy one in the $900-1400 range new. One thing to keep in mind is that this isn't a rebuilt he quoted me, it was for a complete remill. This is how bad the tranny was he said, he could rebuild it but he doesn't trust the other components within the tranny. With that said I still agree $2800 is ridiculously high.
So, I think I am going to go the route of getting a new TH400 that has some upgrades done to it to help with performance. If any of you have links to Summit/Jegs/etc for higher quality TH400s then please share. I don't have all of the information on the history of my engine in terms of HP/torque, but I believe it is slightly above stock as I think there is a mild cam in it. I just took off the aftermarket headers and installed the oversize 2.5" stock exhaust manifolds for the 455. I am guessing I am in the 350-400hp range. I would like a tranny that is equipped to handle up to 500ish HP just in case I decide to amp it up in the future.
Thanks again for all of the suggestions guys!
Mt brother and his BowTie buddies have used Hughes transmissions when local shops failed them. Hughes allegedly has a good rep and a quality product. Their TH400 for our cars is 34-1B. A good Hughes convertor is GM20-400bp or GM25-400bp
Street and Strip - Hughes Performance
Heavy Duty / Street & Strip - Hughes Performance
Summit has these available: https://www.summitracing.com/parts/hup-34-1b and https://www.summitracing.com/parts/hup-gm25-400bp/applications
This should give you some ideas. Ideally I would mate the Hughes TH400 with a Continental Convertor as they have great stall speeds yet drive like a stock convertor.
Torque Converters , CTConverters.com Continental Torque Converters
Best of luck with your difficulties!
Hd th400
Having raced several, and broken a couple, I feel that I can share a little info about the TH400.
The TH400 is very easy to build for high performance or race use. Just a GOOD rebuild, along with a 34 element sprag & firmer shift upgrade, will provide a trans that will easily hold up to low 12 sec drag strip duties, for sure--and probably a lot quicker.
BUT, without the 34 or 36 element sprag, 500ft lbs of torque will break the stock int sprag or roller clutch(if you get traction). The earlier TH400, up thru about '70, had a 16 element sprag. A 34 element is a direct replacement for this sprag.
BUT, the later model TH400's had a weak roller clutch. For these models, the entire drum/sprag/race unit must be replaced with one from either an early TH400, or a later 4L80E. Ebay usually has several of these used units for a reasonable price.
34 element th400 sprag in eBay Motors | eBay
If you have an active drag strip, in your area, you can probably ask some of the racers and find out the name of one or more good tranny guys, who can build a good TH400, for a reasonable price.
But, if not, there are lots of places to buy, on the internet.
CoanRacing.Com | COA-21101-5 | "PRO-STREET" AUTOMATIC W/ HEAVY DUTY 34 ELEMENT SPRAG (STD. PATTERN, BUICK, OLDS, PONTIAC 4" EXT.)
TSI TH 400 Turbo 400 Bop Street Strip Buick Olds Pontiac | eBay
https://www.animalperformancetransmissions.com/products/turbo-400-heavy-duty?variant=1197238925
TH400 Transmission
http://www.transdepot.net/Turbo-400-Performance-Transmission-Stage-2_p_210.html
TH-400 Chevy Street & Strip w/4" Tail HSG & Slip Yoke B.O.P.
Discussion Starter #10
Awesome, thanks guys!
I do have a guy in town that can build me a TH400 with whatever I want. I will use your guys' information and bring it to him. Big thanks!
TH400 Transmission
Turbo 400 Performance Transmission Stage 2
Just to make sure I ask for the correct "stuff" when I get mine rebuilt... Make sure it has a 34 sprag and also make sure the roller clutch is 4L80E?
NO !
Just make sure it has the 34 element sprag. That will insure that it has the correct drum. This drum can come from an early TH400, or a 4L80E.
The TH400 had the correct drum up thru about 1970. But, most of 'em came with a 16 element sprag. I think the 34 element sprag came in some TH400's that were used behind large cube engines, such as the Caddilac 500. The 34 element sprag is a direct replacement for the 16 element sprag. The trans builders don't make there own sprags. Most buy the same one, usually Borg Warner, & repackage. There use to be a GM part number for 'em. Don't know about now.
Starting around 1971 or so, the drum was changed, and the sprag was changed to a weak roller clutch. The 34 element sprag will not work with one of these later TH400 drums. Therefore, the entire drum/sprag/race assembly must be changed out, for either an early TH400 drum, or the drum from a 4L80E. Several trans companies sell new drum assemblies. But they are expensive. As mentioned, used assemblies are for sale on Ebay. My tranny guy had some in stock, when I had my last TH400 built. He has done the 34 element sprag upgrade many times. Any trans guy who has done lots of racing TH400's will be familiar with the 34 element sprag upgrade. :smile3:
1 - 12 of 12 Posts
