Get it off your chest! Internalizing is not good for you!
I looooove this car, but there are a couple of small, minor, niggly things that are annoying. In no particular order:
OK. Whew...I feel better.
- The "MPH/KPH" light on the speedo face. Why is that sucker so bright? When driving to work early in the morning, it's the only bright light in the otherwise excellent cockpit. It just glares out at you, for very little purpose. The dimmer does not effect it. Dumb.
- No dead pedal. WTF were they thinking?
- CAGS. First on my list of fixes.
- Knuckle-busting when putting the car in reverse w/ the emergency brake on. I'm getting use to this, as it's more of a procedural thing: Stow the brake before throwing her into reverse, dummy!
- Long shift throws. Probably more of a preferential thing than an outright bitch, but a car like this deserves a short throw shifter. Great tranny, though.
- Not enough spring tension holding gas filler door open. The other day, I pull up to the pump, forgetting to pop the door, and have to go back around to the panel to pop it open. OK, I'm a dumbass. But then, as I'm just reaching the fuel filler with the nozzle, the wind snapped the door shut again. :shutme
