1 - 11 of 11 Posts
I'm taking the 06 in for the "lock cylinder" replacement and wonder, in your opinion...
What is the most prone to happen mechanical/electrical problem to happen with a LS1/LS2 GTO?
Please share your "short list" of repairs as I need to get a list of obvious ones for the stealership to look for.
Thanks!
Regards...Greg:)
My 04 GTO w/ 55k miles
- rotors
- door handle paint chipped but my warrenty was over when it happened
- stilver trim on steering wheel has a small bubble
Julie's 05 all within 18k miles before she sold it
- 4 rear diffs
- headrest stiching
- battery
- rotors
- CD player - disc was stuck
- ABS sensor failed and hub was replaced(not a common issue though)
There are a bunch more that you can find by looking at different threads too.
-Rear seats (leather busted)
-Light switch was coming out
-leak
-leak
-leak
-leak
-leak
-probably some other visits in there somewhere..
- After all of the water leak visits I just fixed it myself..
1. Front seal on AC compressor went out two weeks after I bought the car new. Took a month to get a new compressor from "down under".
2. silver trim on steering wheel bubbling
Thats it!
Nope, she didn't do burnouts or anything, but did drive very spirited. Her car was stock with just a tune. You should see the GMVIS report, its about 10+ pages long of warrenty work. Hard to belive being that she bought it as a dealer demo too.
I beat the crap out of mine and nothing really has issues. Go figure.
Hey jp...
Is that GMVIS in the forum thread....?
My service mgr wants me to bring in some big time GMVIS reports as he said he's not aware of any probs with the Goat...:eek:
Then again..he's probably only seen one or two GTO's.
LMK....what thread and post # if it is on forum.
Thanks...
Greg
It isn't posted anywhere but I could get the info for you.
VIN : 6G2VX12U55L418459
VEHICLE INFORMATION
Merchandising Model : 2VX37 -2005 GTO COUPE
Warranty Start Date : 10/06/2006
BARS Order Type : 81 - DEALER USED CAR (CVMS USE)
Delivering Dealer : N/A
Selling Source : N/A
Site Code : N/A
Business Associate Code : N/A
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 10/06/2006 0 miles 10/06/2009 36000 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 10/06/2006 0 miles 10/06/2012 100000 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 10/06/2006 0 miles 10/06/2014 80000 miles
36/36000 FEDERAL EMISSION 10/06/2006 0 miles 10/06/2009 36000 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
02/07/2008 118906 # B7288 - HEADLAMP/COMPOSITE ASSEMBLY - RIGHT - REPLACE 11299 miles
02/07/2008 118906 # B7289 - HEADLAMP/COMPOSITE ASSEMBLY - LEFT - REPLACE 11299 miles
01/22/2008 583707 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 11262 miles
01/22/2008 583707 # C7278 - COVER AND/OR PAD, REAR OR ROW 1 SEAT BACK CUSHION - R&R OR 11262 miles
01/22/2008 583707 # N0110 - BATTERY - ONE - REPLACE 11262 miles
08/02/2007 562804 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 10342 miles
08/02/2007 562804 # R0760 - RADIO, REMOVE AND REPLACE 10342 miles
06/30/2005 716645 I Z6999 - PDI RELATED FLUID ADDS 2 miles
05/27/2005 A18459 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
This was it when she bought it. Since then, there has been 2 more diffs, Pontiac arrows faided and were replaced, floor clips broke and were replaced, driver and passenger rear window seals reaplaced, wheel hub, and rear seats. I belive this is everything off hand. But the dealer can run the vin to verify everything if they wanted.
Hope this helps.
IMO based on the reports of owners of this car and the frequency from Original owners of this car in order of what I think were the most reported problems (warranty wise) since 2004:
1. Rear end whine
2. Strut Rub
3. Door actuators
4. PCM/BCM problems
5. Door handle paint adhesion
6. Rear seat seam splitting
7. Fender/Front Bumper clip breaking causing the fender to stand proud of the front bumper
8. Water soaked rear floor boards
9. Gas Cap failings
10. Fan blower motor whining
11.. Steering wheel spoke covers peeling. BONUS complaint (is a close #10)
There are a host of problems that are owner caused, fault codes etc from incorrect installation of CAI's etc, bulbs, failing to clear codes etc used owners attribute to the car when in fact previous owners are the fault not GM.
1 - 11 of 11 Posts
