Hey everyone! First of all let me start by saying this is my first restoration/rebuild and I am still learning. I have been relying on numerous publications to get me through the restoration process. I recently purchased a rebuilt 389 that has been sitting for years (YS motor from a 66 GTO). I will be using this engine for my 69 GTO RAM AIR IV restoration. I will be putting Edelbrock 82cc round port heads on shortly. Anyways.... because the engine was sitting so long, I wanted to make sure everything was lubricated and ready to rock n roll before I start putting it together. I noticed the cam gear dot and the crank gear dot do not line up at the 12 o'clock position. I turned over the engine a few times hoping the dots would line up at 12 o'clock but no luck. When my 1 cylinder is TDC, the cam gear is just about 6 o'clock and my crank is at 4 o'clock. I attached a few photos for you to look at. Here are my questions....
1. is this an issue?
2. how do I go about fixing this?
Thanks in advance!
Thanks in advance!
