What tire pressures do you guys use in your stock tires on the street? I know that the max pressure is 44 psi, but it's not recommended to use the max psi.
PhantomGTO said:What tire pressures do you guys use in your stock tires on the street? I know that the max pressure is 44 psi, but it's not recommended to use the max psi.
sodapop said:door jam says 30
