Don't think so. If both rear tires are the same size (since they are the gripping tires which would be controlled by T/C) I don't think there will be an issue since no diff in wheel spin will be occurring.LYNMUP said:If the computer senses a difference in wheel speed it will apply the T/C measures. Turn off the T/C button and you should be O.K.
That is correct. It is a BOSCH 3-channel traction control system. 1 channel in front, 2 in the back (L&R). The input signals are compared to each other to determine wheel spin.LYNMUP said:I received paperwork form my dealer explaining the T/C system. When the ECM senses a difference in wheel speed from the front to rear tires, it sends a signal to the ECM telling it to kill the power and apply the brakes to the wheel that is spinning quicker. That is how the system is designed to work to prevent the car from spinning out of control on slippery surfaces. So yes! If the rear wheels are "larger" they will turn at a different speed and "possibly" effect the T/C system. But try and see, it may not be enough difference to affect it.
Good luck!
