I run twin electrics behind a good aluminum radiator and a good water pump with a properly clearanced plate on my '69 with a "reasonably healthy" 461. Still, "I've been told" that -nothing- cools better than the good 7-blade factory fan, properly clearanced inside the correct shroud (1/2 in and 1/2 out) driven by a good clutch.
I'm running those electrics because back when I was building this thing I was interested in making all the power I could, but now that I've had them for close to 10 years, let me tell you: there's a WHOLE lot to be said for the advantages of keeping things simple. With a mechanical fan, you never have to worry about losing a fan motor, losing a relay, blowing a fuse, having to upgrade the alternator to pull the load, etc. Any one of those things can leave you stranded on the side of the road with electric fans.
