Is there any way to change the traction control setting to where it's OFF when the car is started, and has to be turned ON ? Rather than the default being ON and having to be turned off.
The reason is obvious to anybody who's done a wheel-spinning launch or pulled has fast shift that would normally spin the tires with the TC in "ON" mode - it's hell on your rear brake pads, and probably the clutch also.
