I noticed today that my traction control is off and I can't turn it back on.
I know, I know...So what, right? But since I haven't done any mods (just a CAI a year ago) I'm wondering what could be causing it. Has any one else seen this before? I have not tried resetting the computer yet. Just thought I would ask around first. I can think of worse things to go wrong, that's for sure! :cheers :lol:
have you tried to see if it engages even though it claims to be off? sounds like a warranty issue which there shouldn't be any trouble getting that solved. good luck and try the traction control out in a safe and controlled environment. (block off the highway from traffic and go at it)
I should try that. I believe it will still engage, but I'll have to find the right time/spot to find out :lol: . First, I will try to reset the computer by disconnecting the battery. I once had a phantam check engine light that
just appeared for no reason. I reset the computer and it was gone and never came back. Thanks for all the replies. My dealer is good, but I don't
want to take it to them unless its the last resort. I'll post up when I find out something.
Since the default with the system is to have the T/C on, there's definitely something with the computer system. Try a reset. If not, have the dealer look at it. Suppose you could check the wiring for the switch, as gaining access to it is really, really easy, but I don't think it will doing anything...
I had the same problem in reverse- my T/C wouldn't disengage. It turned out to be nothing more than a bad switch (the one on the console) which the dealer replaced under warrantee.
Hmmm, that sounds interesting. I wonder if its the switch. I'll
try a reset and then back to the dealer if that doesn't fix it.
I need to use one of my free oil change coupons anyway!
Thanks. :cheers
Just thought I'd post up a final to this thread. Finally got the goat to the dealer today. I had been dreading it although the service department is A+
and has always treated me right (only been in twice though!). The goat
was throwing a code (P0113=IAT sensor reads high). Long story short,
after three hours of trouble shooting, they removed my Volant CAI (I was thinking okay...Here we go! ) replaced the MAF sensor and that was it.
NO CHARGE!:willy: They said that it was causing the PCM to shut down the
ABS system and the trac control even though everything was fine with both
systems. Very strange. Just in case anyone runs into the same thing...This
was how it played out for me. :cool :seeya:
Related Threads
Pontiac GTO Forum
514K posts
38.4K members
Since 2004
