1 - 15 of 15 Posts
Hello,
I will appreciate any help you can give me with this.
I have had my 04 GTO for almost a month now and in the past few days the Traction Control indicator on the dashboard says its OFF and it doesn't change if I push the button.
It used turn on and off when pressing the button but now it just stays off.
Can you tell me what could be causing this problem?
Thanks.
Take it to Auto Zone and see what code is there.
Alot of times its something along the line of something ABS. i know when i had my focus it had TC and then the ABS went and my TC OFF came on and stayed on. Dealer **** fixed the ABS and the light went back off.
Thanks for the quick responses.
A funny thing today, the Traction Control button started working again. I turned on the car and saw that there was no T/C off indicator in the dashboard and then tried the button and it turned off and on.
Now I am really worried. I do have a code checker so I will try that later today.
my 06 a4 did the same thing. I read the codes and the MAF sensor was bad. i replaced it and the traction control started working fine. IDK if it was just a coincidence or actually connected.
Banned
I had the same problem with the TC, the MAF code kept going, My sensor was just dirty, cleaned it off and never had the problem again.
Can someone explain what the maf has to do with the tc??? im lost lol
Awakening an ancient post but I have the same symptoms, TC off without being able to change setting and ABS and brake light on? Any insight would be appreciated
Is there not enough 'insight' in this old thread already?:confused Now, I've never experienced this but it does seem like they did give you a couple of things to look into.
\I would check all your connections under the hood, when i installed a new heat soak sensor into my intake it caused the t/c to stay off permanently. I rechecked the connection and determined it was not clipped in all the way, i fixed this and the traction control came back on.
tc stays off
I replaced the light bulbs with LED and ever sense the TC stays off , went back to regular light bulbs and the problem went away
Just something to check .
hello, I replaced the brake lights with LED light bulbs and the TC stays off tried to push the TC on/off switch to turn it on didn't
work went back to original light bulb , problem went away, Just something to look at , I am sure that was mentioned on the forum before.
5 year old thread........6 if you go back to the original poster.
1 - 15 of 15 Posts
