Have you ever launched your car with T/C on? Bogs down after minimal tire spin. My first 1/4 was w/ T/C on (had it off, but turned my car off in the staging lanes and forgot to turn it off when I restarted the car) and I ran 14.02 @ 102. Ended the day with a 13.3 @ 107. That is a huge difference almost entirely because of the electronic buzzkill known as Traction Control.djray77 said:OK this question concerns T/C, When you turn it off does it give you some added power?? I watched a video where this vette was getting beat (3 times) then he turned T/C off and spanked the guy?? I dont understand this.
I don't know why, but these cars have HORRABLE WHEEL HOP on a track launch.(I guess it's the indipendent rear end) I don't even race mine anymore because of this. I wonder if an air bag or air shocks might help. :confuseddjray77 said:one other thing, when traction is on does that cause the wheelhop thingy?
Mike is right and the drive shaft is a culprit too. It's a two piece design that is only 2 inches in diameter and uses crappy rubber mounts instead of u-joints. Not only do the rubber mounts contribute to wheelhop, they are notorious for failing on even slightly modified 6 speed cars. I am putting on a 3'' chromoly driveshaft with billet yokes when I put on exhaust this winter.big_mike said:I have learned the cause of wheelhop is the soft rubber bushings that hold your entire rear end assembly to the body of the car. Replace those and its GREATLY reduced.
but no, traction control has nothing to do with it.
