finally got my tranny installed. I had to cut my crossmember cause I boxed my frame. I took about two inches out of both sides and welded the crossmember back together and then weld on some brackets that I made to bolt the xmember to. came out pritty good.
:agree Good job! :cheers When you get it all back together, don't forget to double check your driveline angles so you don't get a vibration.
