You will need clutch linkage, bell hsng, clutch, throw out bearing, shifter, etc. Brake pedal may be different too. Crossmember and mount will be different for trans, driveshaft also. Is car a column shift now or is hole in floor already? Will definately be a bit of a project and I'm sure there are more things you will run into other than what I mentioned. Is this a numbers matching car?
