1 - 11 of 11 Posts
Not sure which one is the '67, donor or receiver; however, I believe that the radiators changed from vertical flow to cross flow ~ '66-'67, so the tanks would be oriented completely different.
My 65 is horizontal not vertical
If you have a factory type radiator, you have a tank at the top and one at the bottom. The water flows "vertically" from top to bottom. The later "cross flow" radiators have a tank on the left and right sides of the radiator and the water flows "horizontally" from left to right.
Keep us posted! Do the ST300 lines not fit? 67 GTO was TH400, and I’m not sure if TH350 and TH400 used the same lines. I’m planning to swap a TH350 into a 67 Lemans, so I’ve got the same questions.
1 - 11 of 11 Posts
