2006 GTO A4
I'm getting a transmission from jasper engines. The mechanic that is going to install it says I need to reprogram my ecu. Is that true? I haven't seen anything about that anywhere on the internet. He's also saying I need to balance my drive shaft which I had replaced 5 years ago. He's also saying I should replace my crank shaft seal housing to prevent oil leaks in the future. He also says my oil pump isn't pumping out enough pressure anymore which I might believe because I keep getting a check oil light even though my oil is full. Does the check oil light come on for transmission fluid low level cuz I had a transmission fluid leak.
Will reprogramming the ecu do anything when getting a rebuilt transmission? Also do you think any of the other recommended fixes will help?
I drive my GTO easy
The reason I'm getting a rebuilt transmission is because I couldn't get into 3rd and 4th. From everything I've read it requires a transmission rebuild.
I drive my GTO easy
