baron_iv said:http://cgi.ebay.com/ebaymotors/Pont...ryZ38634QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
There's the link.
My only concern with this (other than the fact that the hood may not allow "cold" air in) is that you are removing your radiator shroud, which will allow heat to get up there around the filters, so you'll be sucking in even HOTTER air than before, possibly.
I'd like for someone with an extra $360 lying around to give it a try though. haha
Gap, what gap? You mean the 1/4 inch spacing between the hood and headlight? I suppose it is sucking in air above the driver side headlight.
True, but it looks like it would be a better CAI than most out there. Although it is not true ram air it should still have plenty of access to near outside air tempatures. It would be warmed slightly simply due ot being where it is, but I wouldn't think all that much.That kit is not a true ram air kit. More like a fancy CAI.
hi all the intake your talking about is a otrcai (over the radiator cai) it requires a maffless tune ,are u aloud to run no maff over in us,but does not fit monaro (gto)with vented bonnet ,if you want some info go to street commodore forum or ls1 & holden forum theres lots of post on these sitesThat looks like it should work. I saw an intake on this forum from Australia which was similar. The scoop looked like a metal oversized vacuum cleaner attachement. It attached directly to the throttle body and extended over and down in front the radiator and the scoop would be catch air in front of the radiator. I think it came with a replacement shroud.
I can't find that link or website now. These two intakes would seem to be the best if they work, because of the short distance for air to travel.
how is it going down under, thought that monaro was the same thing.hi all the intake your talking about is a otrcai (over the radiator cai) it requires a maffless tune ,are u aloud to run no maff over in us,but does not fit monaro (gto)with vented bonnet ,if you want some info go to street commodore forum or ls1 & holden forum theres lots of post on these sites
cheers vxssls1
Is there a shot of the hood on that car, is it an 05-06 hood on an 04?Check this mod out. Looks like the closest thing to true ram air so far. http://coldairinductions.com/images/DSCN4862.jpg
Because, depending on where the air inlet is, that may not be the closest thing to ram air, that may be Ram Air.
