1 - 9 of 9 Posts
My turn signals do not work, when I step on the brakes both turn signal lights light up on my dash and on the front of the car (I can see the turn signals in the reflection of the vehicle in front of me) I’m assuming it is a relay. Brake lights and tail lights work fine. Any previous experience with this issue would be greatly appreciated.
Also, check the connections at the large horseshoe plug under the steering column. They can back out and get loose, and give you issues as well. BTDT.....
Also, check the ground wires on the taillight assemblies themselves. I just had to replace them yesterday because mine weren't working. The ground wires were old and had a bad connection.
Check ALL the bulbs for blow outs, then check BOTH flasher units....FIRST check the fuses......................go from there.
Replaced all bulbs, fuses and flasher fuse. Using a test light , I have power to my turn signal switch but not after. Ordered new switch will be in next week. Will keep informed, thanks for all the input
Sent from my DROIDX using AutoGuide.Com Free App
Replaced switch, turn signals work!! sorta they won't turn off after turn. Also installed aftermarket grant steering wheel. Will investigate when steering wheel removal kit arrives, ETA?? Been waiting over 2 months, called year one and was told it will be at least another 2 months. Thanks for everyones input
Sent from my ADR6425LVW using AutoGuide.Com Free App
1 - 9 of 9 Posts
