I have idiot lights in my 72. I will run the stock blade type sender in the head where it should be. I also want to set up a set of gauges. So, is the best place to put the button style sender for a gauge in the intake? I assume I don't need that for the purge valve if I don't want to plumb that, even if I use the evaporator canister for emissions?
Banned
There is a flat spot on the driver's side of the manifold next to where the thermostat goes.
That spot can be drilled and tapped with a 1/2 in. pipe tap for the gauge sender.
