I just bought a fresh 12 bolt for the 65. My question is my driveshaft and old axle are out of a 442 with 3R ujoint. New axle is 1310 and old was Saginaw 3r. Can anyone tell me id the Saginaw 3r is the same as the spicer 1344. I am trying to find a conversion u-joint from 3r to 1310 and I can find 1310 to 1344. Dimensions are very close. Any help is appreciated. I would like to find something strong and not just a store brand. Thanks
GTO's (and Pontiac LeMans) used the 3R ujoints from '64-73. 442's always used the 3R. Most Chevrolet 12 bolt rears accepted the common Spicer 1310 .
The conversion ujoint you need is a NEAPCO 3-1330, Precision 372 will also work. In building differentials I always build with the correct pinion flange, so don't have to deal with adaptor ujoints.
Thanks .The Precision 372 is one of the ones that says 1310 to 1344. Thats what I wanted to verify. I can get the moog 372 locally just wanted to make sure it would fit. I am not r running crazy HP but I wanted to make sure I got a strong ujoint. Any issues with strength either of these part numbers you gave me?
Some of the guys over on the Pontiac Drag Racers Facebook page say they have broken joints, which in turn, caused a lot of other damage.
They tried to talk me into going with a shaft which uses the big 1350 joints. But, I just have a mild pump gas 455 footbraker bracket car. I don't need the big joints.
Then, somebody else said that if I was going to use the small 1310 joints, I should at least get the non-greasable kind. They say that the threaded hole and grease channels, weaken the joint. But, I've never broken a greasable joint before. And since I'm not using a trans-brake, I don't think I'll break one now.
http://www.wranglerforum.com/f210/u-joints-greasable-or-non-greasable-356026.html
"... or a manufacturer making a crappy one."
I've read that there are some inferior grade Chinese joints & slip yokes.
http://www.made-in-china.com/multi-search/car+u-joints/F1--CD_Universal-Joint-Catalog/1.html
