How does the u-joint bolt onto the pinion yoke on a 67 Lemans/GTO? is it with straps or u-bolt type?
I've had my 67 for two years and just now have reached the drivetrain.
The car came with a driveshaft, about 61" center to center. This seems a bit long for a th400. Seems to me that it may be off of a lemans 326. I could be wrong. Any info is appreciated.
Hello
that does seem long.... correct length is 60" for the 2 speed cars center to center on u joints...
did you measure overall length ?
also
u bolts on our 10 bolts w nuts and lock washers
t 400 trannys are 5/8 of an inch approx longer than the early muncies thru 70
so
the t400 driveline is 60 minus 5/8" = 59 3/8 " center to center for the 67 GTO...
I have a nice 67 GTO drive line for the t 400 and correct original u bolts and hardware if needed
Scott
206-4six5-9165 Lacey WA
Thanks for the reply. I looked today and didn't see threads inside the pinion yoke so it looks like u-bolts. It does actually measure 60", I'm just retarded. My retardation lead me to get the wrong u-joints tho.
Once I get the shaft in, then the interior and rear brakes and she'll be road worthy!
