http://www.rsportscars.com/eng/cars/vauxhall_monaro_vxr.asp
Read the article... They believe it can do 180+
If you think about it, its not that far fetched...
The vette w/ the same LS2 engine does 186 in 5th w/ 3:42 and slighty differnt ratios then the goat(the gto has the M12/C5 Z06 ratios)
Also weight does not restrict top speed, it just takes longer to get there... If you dont believe that, take a look at the Bentley Continental GT. It weighs 4000+ lbs and tops out @ 205 w/ the same HP as the Ford GT and the GT tops out around 205(if the wheel doesnt fall off :rofl
but weighs about 1000 lbs less...
So if the GTO is aerodynamic enough maybe the 05' could reach 175+ w/o the limiter...
A little food for thought :cheers
