does a cold air intake void the warranty?? anyone know for sure? I also want to do a slp muffler and just remove the stock muffler. willl this void the warranty.
Thanks,
Chris
Thanks,
Chris
True, but its the car coming in with oil soaked filiter, intake, MAF, the dealer has the complaint's with. The excess oil throws the codes, causes the running problems and I can see if you're stupid enough to let that happen by overoiling you're filter, then the dealer has the right to deny, deny, deny (like the horny presidentTexasRealtor said:I have heard of GM voiding a warranty on Z-28's for using a CAI with the K&N filter setup. Keep your old intake and put it back on for ANY warranty work to be safe. Also, any exhaust system that does not effect emmissions (i.e. catback) should not effect the warranty. If you start putting on headers, etc. then they may void it.
:agreewestell said:True, but its the car coming in with oil soaked filiter, intake, MAF, the dealer has the complaint's with. The excess oil throws the codes, causes the running problems and I can see if you're stupid enough to let that happen by overoiling you're filter, then the dealer has the right to deny, deny, deny (like the horny president)
