68-72 A Body entire rear end with posi -
12 Bolt preferred
low 3.xx ratio preferred
not needed to look pretty -
BOP or Chevy ok
will consider 10 bolt Corporate posi
Boston Area
Thx
C
Good luck !
Back in the good ole days, I bought several for $100-$150. Those days are LONG gone.
A decent used 12-bolt will probably cost near $2k. New 12-bolts, with disc brakes are closer to $3500.
If you are real lucky, you MIGHT locate an 8.5" 10-bolt that came out of an Olds or Buick, from the early '70's, for $1000 or less. But, by the time you have it rebuilt correctly, with good parts, it'll cost over $2k. 'ol Pinion Head, who use to post here, has built lots of these, & probably has some cores in stock.
Some go with 9" Ford units. One with a good chunk will probably cost at least $2500. Some have posted good results with the Quick Performance 9" units. But, not all recommend them.
With the weaker stock chunk, these are $1865 + tax + S & H. Upgrades cost extra.
https://www.quickperformance.com/9-Ford-Complete-Rearend-GM-A-Body-68-72_p_20386.html
Here's some Ebay 12-bolts.
https://www.ebay.com/itm/12-BOLT-1968-72-CHEVELLE-POSI-REAREND-REBUILT-GTO-442-MONTE-CARLO/283611550770?hash=item420890d432:g:40IAAOSwUTZcj5d3
https://www.ebay.com/itm/12-BOLT-68-72-chevelle-monte-REAREND-REBUILT-NEW-GEARS-BEAR-POSI-axles-CHOICE/143149988819?hash=item2154677bd3:g:wF0AAOxy8HlSawkD
https://www.ebay.com/itm/CHEVELLE-CUSTOM-BUILT-CHEVY-12-BOLT-REAR-END-EL-CAMINO-A-BODY-GS-OLDS-AXLE-DIFF/262191884074?hash=item3d0bdaa72a:g:S4IAAOxye3BRr9~-
The Moser Muscle Pak is probably one of the highest priced street 12-bolts. Will be near $4k shipped.
https://www.moserengineering.com/12-bolt-musclepak.item
Here's a Currie.
https://www.currieenterprises.com/64-72-gm-a-body-12-bolt-rearend-builder
If you are going aftermarket......I would go with the Strange Engineering S60; their interpretation of the Dana 60. Damn near indestructible and no more expensive than any of the other options out there.
