Hi All
I took the windshield washer motor out when I painted the engine bay. After installing the washer motor, the wter pump didn't work. I changed it and same thing. I hear it ticking but no water comes out the nozzles. I checked the washer bottle, hose, and nozzles. Everything fine. Don't know what's going on?
Sounds like something fell out of alignment. If your sure it was working before?
You need to carefully remove just the pump and check the Ratchet/Wheel, Pump arm and Motor Cam.
Be mindful of the Cam (Little Star shaped piece)as it sometimes falls off.
