i like the 326 engine. i would reseal it and if it ran good put it back in. drive the wheels off it. but if i were going to build an engine a 400 would be my choice.
Awesome car! White with black gills... too cool!Thanks for all the reply’s! We were out cruising around in the car today & it does run good but feels like a slug. I was thinking about installing a 200 4r eventually but maybe I should prioritize it instead? I always regretted not installing one in my Skylark when I installed a rebuilt turbo 350.
Very nice, you could always find a stock 4 barrel intake and carb, some better rocker arms and a good timing curve to wake it up and then the trans sounds like a good idea or how about some different rear gears depending on what's in it now idk just some random thoughts.Hi folks, I just purchased a 1967 Lemans with a 326 & a 2 barrel carb. The car is pretty original so I want to stay with the 326 for now but I’ve never owned a Pontiac before. My experience is with Chevy small blocks & my previous Buick 350.
Right now the 326 runs decent but everything is leaking so I’m thinking of pulling the motor to reseal it, maybe freshen it up depending on what the compression readings are. What are my options at this point, can I make the little 326 a decent street runner or should I just start saving my money & energy for 400? Is it worth doing the traditional cam, four barrel intake & headers or just move forward with a new build?
It does have a PCV valve, I pulled it & it rattled so it’s not stuck. Here’s a pic under hood, I’m not sure that it’s the proper hose routing but it looks old….Coming from Chevy, you may not know this, and I didnt see it come up in here yet... but Pontiac doesnt have a smal block and big block. The 326 engine is no different then the 400 or 455. So...
If you pull the engine to reseal it, you can swap out the rotating assembly and make it into a 350, 389, 400, 455, 461.
Also...
If you're leaking everywhere, please look at (or show us) you PCV valve and breather setup. If it's wrong, you'll get leaks galore. These can be fixed with a correct setup or a Wagner PCV valve.
And if that's the case, throw some 373's in the diff and and get some Cherry Bombs, and leave it as is
Well you have no breathers so it's no surprise you have leaks, why is there a plug in the passenger valve cover and not a breather ? I would put two breathers and a Wagner adjustable pcv. I'm assuming the pcv is in the rear of the valley pan where the hose disappears but I don't know 326's then what is the T for and what does it go to under your carb, can't see.It does have a PCV valve, I pulled it & it rattled so it’s not stuck. Here’s a pic under hood, I’m not sure that it’s the proper hose routing but it looks old….
What's that flat plate with holes in it in front of the passenger valve cover for, a/c ? And he was looking for some simple power increases so I thought some new 1.52 roller tip rockers would help, I know it's not clearanced for 1.65's but what do I know.That is as Fact Tree as it gets, from the original rubber valve cover plug on the pass side to the indent on the timing cover for a tripower thermostat to the special washer on the timing cover to intake bolt. Carb looks recent. Very much the survivor. If you pull the engine to re-seal it and replace the trans, do yourself a favor and check the timing chain slop first. If it has slop, it may still have the original nylon cam gear and you should change the timing chain set. The nylon cam gears like to shed teeth and you end up bending valves. The recommendation to mess with the rocker arms, etc. would not be something I would do. Keep it simple, and it will be low cost and dependable for many years to come. The more you tweak on it, the more thirsty it will get, the more expensive, and the less reliable. Fact.
Ah yes, the infamous GM plastic cam gears, great point, I will definitely keep that in mind! The seller told me that the motor is not numbers matching but if it was replaced it was obviously done a long time ago so it probably looks factory still.That is as Fact Tree as it gets, from the original rubber valve cover plug on the pass side to the indent on the timing cover for a tripower thermostat to the special washer on the timing cover to intake bolt. Carb looks recent. Very much the survivor. If you pull the engine to re-seal it and replace the trans, do yourself a favor and check the timing chain slop first. If it has slop, it may still have the original nylon cam gear and you should change the timing chain set. The nylon cam gears like to shed teeth and you end up bending valves. The recommendation to mess with the rocker arms, etc. would not be something I would do. Keep it simple, and it will be low cost and dependable for many years to come. The more you tweak on it, the more thirsty it will get, the more expensive, and the less reliable. Fact.
Yes, PCV is in the rear of the pan. I’m thinking that I should replace the hoses & the valve to start fresh. What kind of breather for the passenger side valve cover? Where would I put the second? In the oil fill hole?Well you have no breathers so it's no surprise you have leaks, why is there a plug in the passenger valve cover and not a breather ? I would put two breathers and a Wagner adjustable pcv. I'm assuming the pcv is in the rear of the valley pan where the hose disappears but I don't know 326's then what is the T for and what does it go to under your carb, can't see.
We believe that the car had an aftermaket AC at one point using that bracket, there’s also two holes that were sealed up in the firewall that the lines probably ran through.What's that flat plate with holes in it in front of the passenger valve cover for, a/c ? And he was looking for some simple power increases so I thought some new 1.52 roller tip rockers would help, I know it's not clearanced for 1.65's but what do I know.
Well the experts would know which breathers were stock if they had them at all but if you're not worried about absolute stock looking then find a Pontiac push in breather and a half twist oil filler breather I guess. So where does that pcv hose go that's hidden under the front of the carb? I guess maybe Pontiac didn't put breathers in but if you have several leaks I would think that's part of the problem is crankcase pressure. At idle the pcv is taking in crankcase fumes and putting them into the intake to be burned drawing in outside air through the breathers but when you get on it the pcv valve drops out do to no vacuum so then the crankcase pressure goes out the breathers...which you have none so the pressure is causing leaks. I should probably be fact checked but that's my understanding, I've dealt with this issue on my 461 with it popping the dipstick out on hard runs but luckily no leaks.Ah yes, the infamous GM plastic cam gears, great point, I will definitely keep that in mind! The seller told me that the motor is not numbers matching but if it was replaced it was obviously done a long time ago so it probably looks factory still.
