What can I do with my 326?
2970 Views 85 Replies 24 Participants Last post by  DustyOldGTO
Hi folks, I just purchased a 1967 Lemans with a 326 & a 2 barrel carb. The car is pretty original so I want to stay with the 326 for now but I’ve never owned a Pontiac before. My experience is with Chevy small blocks & my previous Buick 350.
Right now the 326 runs decent but everything is leaking so I’m thinking of pulling the motor to reseal it, maybe freshen it up depending on what the compression readings are. What are my options at this point, can I make the little 326 a decent street runner or should I just start saving my money & energy for 400? Is it worth doing the traditional cam, four barrel intake & headers or just move forward with a new build?
  • Like
  • Love
Reactions: 2
41 - 60 of 86 Posts
I had a 326 2 speed auto in a 1965 Tempest. I’d also rebuild it rather than a 400 swap, especially if it’s a no.s matching. However, if you have the two speed I’d pull that and switch it for something that’ll give you better performance and gas mileage
  • Like
Reactions: 2
Let’s not forget to mention the rear. If you have an open rear with 2.73’s, you’d get a lot of bang for your buck with a posi and 3.23’s, and the 326 would be very receptive to the new gearing.
Sent from my iPhone using Tapatalk
  • Like
Reactions: 2
Yes, new gears with a posi is in the cards for the future.
  • Like
Reactions: 3
Fishwater, nice Lemans.
A friend in HS had the same year, same drivetrain. It would shift into 2nd at about 60 with foot to the floor, which is pretty much how he always drove.
"It's a dog, but great on the highway."
You probably have 2.94 or even 2.56 rear gears. If you swap in a T350 it's going to give you the equivalent launch of swapping to 3.73 gears with no change in highway manners.
The 200R4 has an even lower first gear.
Do the basic maintenance recommended by others but make the transmission swap your first performance enhancement.
A nice dual exhaust would next on my list.
Cheers
  • Like
Reactions: 3
The 200r4 would wake your car right up. Great off the line and great on the highway. With the 326, probably over 20mpg. Your car looks like a nice original. I personally would forgo engine mods at this time and just fix the oil leaks and do the trans and go from there.
If your going to pull it and reseal it I highly recommend replacing the timing chain and gears. I'd check the cam for flat lobes while your at it.
  • Like
Reactions: 3
So I’m a little behind on pulling the engine & resealing, it sounded like an easy quick project BUT I’m too busy driving this car & having a blast! So far I’ve put about 500 miles on the car since getting it, I’ve added two crankcase breathers as recommended, changed the oil. I’ve installed Year 1 Rally’s with 245/45/17’s up front & 275/40/17’s out back, still need to install my front disc brake conversion, control arms, coil overs, ties rods, center link, etc. to completely rebuild the front end with newer more modern hardware even though it’s still incredibly tight even though every bushing looks a million years old.
Unfortunately the oil pan/rear main seal leak is getting worse & worse, tons of drips everywhere I park, overnight or not so that really needs to be addressed but maybe I can wait until winter? The car cruises along at 65 mph without breaking a sweat, the little two barrel just hums away bringing a smile to my face every time I drive it. This little 326 is impressing me, I know people say not to waste time with it but it runs so freaking good! Until I can find a 400 to build I’m thinking I’m going to play with the little 326 to see where it can go. Right now & the main reason for the update is that I’m thinking I want to add something really cool to the car to keep with its original theme so I’ve located a 1966 tri power set up that is reasonably priced, available locally & freshly off a running car. So my question is, how’s the tri power for the “small” 326? The motor is all stock & looks original but when listening to the idle I question if it is really stock, clip below for your thoughts. The car has a 2.25 dual exhaust from the factory manifolds into dual cherry bombs, sounds pretty freaking good to me!
See less See more
  • Like
  • Love
Reactions: 5
No clip.
It probably runs rough due to age, but sounds better than stock. Have had a couple cars like that as they sounded better because the exhaust made them sound better, but they ran a tad bit rough.
The 326 is a bit underrated. You can have a little fun with it, but up to a point, and then most want bigger HP/TQ so they swap in the 400. The 326 HO version was to compete with the Chevy 283 Hi-Po engine. I learned to drive on my dad's 1965 Impala 283 3/speed on the column and it was lots of fast fun. My brother thought so too until he blew the engine up and had to replace it.
Can you put a tri-power on it? Why not. The issue as I see it is that at this time, it may be more carb than the engine can use ad will bog out on you at the lower RPM's. BUT, who says you have to use/hook-up the outboard carbs? Fake it a little and run on the center carb for a while. You can put block-off plates under the carbs to seal them off. You can try the outboards, but you most likely won't see gobbs of power and just drop gas mileage.
If you keep the 326, then you want a bigger cam that will take the tri-power. If you get a 400CI, you can also use the tri-power.
So it is your call. If you like the 326, keep it. If you want a 400, then swap it.
Car looks good.
(y)
See less See more
  • Like
  • Helpful
Reactions: 4
Thanks for taking the time to respond. The car definitely runs good, fires right up, crisp response to the throttle & minimal if any smoke on start up or acceleration. I think I compressed the clip enough so let’s try it again, just click the link below it’s safe. Funny story, we went to a car show Sunday in the car, I wasn’t entering, just parking to walk around & then security directs me towards the show field, just as I’m telling them I just wanted to park they had me the entry card & pointed me down the hill to the field :LOL:
See less See more
  • Love
  • Like
Reactions: 3
i like the 326 engine. i would reseal it and if it ran good put it back in. drive the wheels off it. but if i were going to build an engine a 400 would be my choice.
The way gas prices are nowadays...I am starting to like the sound of smaller cubes and even 6 cylinders are sounding pretty good for cruisers
  • Like
  • Haha
Reactions: 3
a good stock build and an overdrive.
  • Like
Reactions: 2
On the contrary... I said "leave the 326 as is and install some cherry bombs and 373's". I would absolutely wast my time on a 326
  • Like
Reactions: 2
Ive seen a lot of tripower scams, so do your homework. If it's a pre 65, it wont fit your engine, either. Personally, I'd same my money. You could do a cam, manifold, and 4bbl for the same money and same amount of work.
  • Like
Reactions: 4
That happens to me about every summer, all summer. I never enter shows, but either my car gets dragged into them anyway, or it draws a bigger crowd in the parking lot. Get used to it.
  • Like
Reactions: 2
Fixing my exhaust leaks and going up in tire size, had an epic impact on my mileage! I used to fill up twice a day, now I go a week without it!
  • Like
Reactions: 2
I’m not worried about fuel mileage, it’s a toy so it doesn’t matter as much as my daily driver.
  • Like
Reactions: 3
I agree with that, isn’t a bad idea but it’s not as cool as tri power ;)
  • Like
Reactions: 2
A matched cam, intake, and carb, is definitely cooler than a tri power flooding an engine, but it really depends on what you're going for.
If your goal is to impress others, then yes, you can simply add two carbs to your existing setup and let er rip!
If your goal is to impress yourself and your passengers, then match your parts!
I'm biased on this... I own my favorite car, so very little impresses me at a car show. I do like cars that came with tri-powers, but then again, all Pontiac fans know that the most powerful GTO's (by far), had 4bbls.
This being said, it's your opinion that matters, but allow me to say this:
You started this thread by stating that this was your first Pontiac, and now you've had several of this sites most notable members, try to talk you out of putting trips on. This is like the Rolling Stones telling you how to be a successful rock band. There's a ton of critical knowledge here, that will likely save your ass some day, so learn how to spot it when it crosses your path.
See less See more
  • Like
Reactions: 2
Yes you can run a tripower. what most people dont realize is 75% of the time you are running off the center carb only. End carbs kick in only under heavy to full throttle. basically the center carb is like the primaries on a 4 bbl. End carbs are essentially the secondaries. Center carb has the idle and transition circuit, choke, and power valve. End carbs dont have any of these circuits for normal driving, just WOT air and fuel
you could reach out to john at pontiac tripower and ask if they have jet recommendations. What he gave me for set up parameters in terms of jetting, float level, idle tube dimensions etc were spot on. I would think yo7 could adjust the progressive linkage to not fully open the end carbs if it is too much airflow
would just be careful buying a used tripower that someone janked off. A lot of them are pieced together from incorrect carbs and poorly assembled.
i put a tripower on my 65 which it came from factory with but was long gone when i towed the car hime 33 years ago. i have fallen in love with the looks and sound when it is wide open …
See less See more
  • Like
  • Love
  • Helpful
Reactions: 3
Hmmmm. And wanting 2x4's on your engine build, is that to impress yourself, your passengers, and others? :cool: Hell ya, isn't that the ENTIRE reason we have Pontiacs in the first place, to IMPRESS the world - especially the chicks.
If you have not experienced mulitple carbs, you have not lived.
(y)
  • Like
  • Love
Reactions: 5
Ok, so if I did a matched cam, I take & carb what are some suggestions? I realize a single carb matched to the proper intake & cam make more HP on a dyno but so do headers & having had plenty of sets over the years with small block Chevy’s as a kid growing up & my last Buick 350 the headaches aren’t worth the extra 10 ponies in a street car. Either way I’m open to single carb or tri power, I’m here to learn & have fun.
  • Like
Reactions: 2
41 - 60 of 86 Posts
