Hi all,
a lot of confusion here in France regarding this subject:
what kind of gas should I put in my 65 GTO 389CI V8?
currently I use unleaded 98 plus lead additive;
is that correct?
some guys here says they use 95 without additive;
so, where is the truth?
thanks for your feedback;
Eric:frown3::frown3:
hi, gtoguy,
the confusion comes from the fact that all the engines were designed in the 60's according to the leaded fuel used at that time;
the unleaded appears later in the 90's;
so the fact there is no more lead does not harm the valves?
You have that backwards. Lead helps the valves to not wear themselves up into the head. Hardened valve seats were introduced when unleaded gas was becoming a reality. In 1973 it was mandated with the 1974 model year.
The United States uses the R+M divided by 2 method to advertise octane. Don't believe Europe uses that method, just Research Octane number. You really need to study & find out what "95" actually is, I'm betting it is much lower R+M divided by two.
