I know I need the clutch, PP, TO bearing, bellhousing. But what about pedals and z-bar mount? How difficult is it to install these?
Wade
You will need pedals...not too difficult. A flywheel and pilot bearing. A shifter and maybe a console. Is the car currently a column shift?...if so you need a different steering column. You can save a LOT of hassle and BS with clutch linkage by using a hydraulic throw out bearing...................also, consider a 5 or 6 speed, you are doing the labor anyway.:cheers Eric
