RIP (12/27/60-7/18/15)
Wow, that's cool thank you!
er..............what does it do?
As far as i knew(lol) the only wire going to my trans was for the Tac
thanks again
makes the trans downshift when you press the pedal way down. (passing gear) it should be the only wire going to the trans. tach gets its signal from the ignition.
It is for the 400 turbo. It drops into passing gear(automatic down shift) from an electrical solenoid on the side of the trans. Unlike the 350 turbo, that uses a cable that runs from the carb to inside the trans next to the cooler lines.
So that is the switch to run the solenoid at close to full throttle. I am sure they put it inside the car, so it would last longer then being in the elements
