1 - 12 of 12 Posts
After trying to separate hub from drum on my 68, unsuccessfully I might add, I noticed three of the studs had a retainer ring of some type at the base. (see pictures) What is the best way to remove these so I can separate the bolt from the hub?
I dont think your s come apart for servicing ....
mine have a slide on drum like the rear
fairly sure yours are press fit and the whole unit gets replaced,,,
Scott
got a picture of the backside of yours ??
I have hit them with a chisel and tried to knock the lug out but no luck.
If nothing else, the lugs should come out as sometimes you have to replace broken studs.
I have found the trick is to make sure the studs have solid support behind them. Just beating on them may not knock them through because the drum has flex and absorbs the impact.
I find a socket or steel tube that will fit around the back of the stud. Then set that on something solid that fits up into the drum - like a brick or two or..... so you have the drum up off the ground firmly supported by your socket/steel tube. Then beat the stud with the BFH to knock it through.
They sell new drums and new hubs. So if me........ that baby is coming off or going in the trash. :yesnod: But I also have torches and my favorite die grinder/cut-off wheels. :thumbsup:
Scott
here is the back side of the hub.
yup
I dont think yours are the 2 piece
headed out to the shop to box a few sold items up and I will take a few more pics...
as I am putting the hubs back on tomorroow....
Interesting. So I pulled out the Restoration book and it says that a different drum & hub assembly were installed on 1968 cars in limited quantity. The drum & hub were separate allowing just the drum to be service. This drum & hub assembly was installed on cars beginning from VIN P268122 (from Dealer Service Information, dated 5-13-1968). So your car may or may not have the 2-piece drum/hub combo even it followed VIN P268122.
If the front drums had to be turned, the hub & drum had to be turned as an assembly.
Thanks for the input Jim, the other assembly was a two piece unit. So it seems I have a mixed bag(LOL). Have ordered new hub to go with the new drums and other brake parts. unfortunately the only original parts left will be the backing plates , spindle and steering arm.
so you have 1 slide on and 1 1 piece drums
well ......... heres one for you
got ready to finish assembling the front brakes as my other brake hose came in
and..........
ohhhhhhhhhh yahhhhhhhh ISSUES !!
the Raybestos brake drums lug hole are WAY to big probably made for your style drum
with the crush sleeves around the stud ...
so I am off to return em and have my originals turned..... what I should have done anyways ....
yup ..........
way sloppy on the new drums
perfect on the originals last picture
1 - 12 of 12 Posts
