I have a 69 Lemans with a 400. swapped out stock rear end for 12 bolt posi with 342 gears out of a 70 Pontiac, really bad wheel hop off the line, any suggestions with dealing with this would be appreciated.
Really violent wheel hop will break things - like the frame. A jacked up rear end makes things worse.
First would be all new bushings. Worn bushings can be a cause - too much play.
Dick Miller has some good products. His book is a must if you want to get serious about traction: https://store.dickmillerracing.com/rearsuspensions.aspx
If the rear end is jacked up, you may want "no-hop bars." If you do a web search using that term, you should pull up a couple different styles. https://www.summitracing.com/parts/qa1-5213?seid=srese1&gclid=EAIaIQobChMIuIrVgKmG5AIVD5SzCh0chAiBEAQYAyABEgLDivD_BwE and
If stock height or lower, you might use Rear Control Arm Relocation Brackets: 1964 - 1972 GM A-Body Rear Control Arm Relocation Brackets - Bolt-In [4012] - $149.99 : UMI Performance, Inc.
You might also try a different rear spring and/or shock absorber.
You can also change suspension geometry that alters your Instant Center. http://www.wallaceracing.com/coilspring.htm
Highly suggest upper/lower control arm braces if you are going to use that throttle to its fullest at stop lights, stop signs, against rice burners, and LS Chebbies. :thumbsup:
What Jim said, also the simple load handler air bags inside the coils will allow you a little adjustment for rake angle without screwing up pinion angle and reduce a little of the roll and oversteer in corners.
Thanks for the help. I will start going through the links you sent and I will definitely look into your suggestion
