In the age of the internet, start digging! "Tempest search" Craigslist, or check in to OPGI, Perfromance Years, Ames, Year One, etc. Ebay it.
It may be a tougher hunt and more expensive to find originals.
They arent reproduced in steel, only the 70 is. Lucky for you LeMans and T37 fenders will work with a minimum of effort. You could use the 70 fenders if you can rework the area where the bumper sits. Unless yours are bashed up all of mine are probably in worse shape. Got any pics of what you are working with, because they might not be that bad.
try using SearchTempest - The EASY way to search Craigslist. It searches as much of Craig's List as you tell it too, based on miles from your zipcode/city. Just make sure to click on auto parts, or else it will give you all kinds of crazy things back.
There have been lots of them on the Ohio area craig's lists lately.
Russ
1964-1974 Tempest, Lemans & GTO General Discussion
I'm getting ready to purchase a clutch and pressure plate for my 69 Judge. The engine is a mostly stock ram air 3, other than the hydraulic roller cam. My flywheel is the 166 tooth one, approximately 13-5/16 in diameter and the transmission has the 10 spline input shaft. It's a restoration and...
I am readying my engine for paint. One bolt unfortunately broke and whats left of the bolt wont budge. We have soaked it in PB blaster, heated it, welded nuts to it....just wont budge.
I am installing Ram Air manifolds.....it is the forward left exhaust port...right bolt. If we just cut it...
Hello Forum....I am new to this forum. I recently purchased a 1968 GTO convertible. I feel pretty lucky that I was able to get it. The caris in kinda rough shape....needs a lot of TLC.
Here is a picture or two...
Just stumbled on this little device. Did some quick searching and have yet to find a bad review. Anyone running or tried one of these on their carburetors? Suppose to make your shot of fuel atomize better.
https://thompsonperformance.com/
