Most likely not. Don't most trucks use leaf springs, or has that changed? A-body cars use coil springs.
Your control arm and spring mount locations will be completely different and even pinion angles could be different. You can cut down a rear end, but not something the average guy would do or have the tools to do so.
It might be possible to get a bare aftermarket rear axle set-up to fit the A-body rear suspension and then swap the guts from a donor over to the bare housing. I used a Quick Performance Ford 9" axle housing set-up for an A-body ( 1968 Lemans) which included the axles (I got 31 spline axles, but I think stock on most 9" is 28), heavy duty wheel bearings, and got the heavier axle tubes. I also purchased the 11" drum brake kit, but you might be able to retro fit a disc brake set-up pulled from a junk yard. Then you need the front carrier complete from a Ford 9" that uses the same splined axles as the ones you have. That should for the most part be what you need. Never done this, so don't hold me to it word for word - just a possibilty that may work.
The 12-bolt would require more work as you have to set up the gears as they do not have a
The 12-bolt would require more work as you have to set up the gears as they do not have a removeable third member/carrier.
Thanks, the 9" did say it had 31 splines. That's why I was wondering if it could fit.
