Hey guys, so iii had a friend come over with a torque wrench to properly torque the crank bolt, basically the way iii had jammed a wrench to keep the harmonic balancer from rotating while iii was REMOVING it did not work for keeping it from rotating while INSTALLING it.
My boy decided it was okay to spin the balancer clockwise (in order to get the wrench to lock in place) because the keyway was locked in.
The second pic is how it used to be, with the two holes directly on the bottom. First pic is how it is now, two holes at the teeth,
Im wondering hardddd about if this threw off the timing?
Should i turn the balancer counter clockwise back to its original position?
Or is it fine & im juss overthinking?
