I wanted to put the black z06 rims on my black 05 goat.I've heard the lug pattern does'nt match up.Does anyone know if this is true?
I don't think so but I'm not sure. If you go to the Tire Rack or Discount Tires website and select the wheels for a Z06 it will show you the bolt pattern for the wheel. Hope this helps!wildchildm39 said:I wanted to put the black z06 rims on my black 05 goat.I've heard the lug pattern does'nt match up.Does anyone know if this is true?
5 spoke WS-6 wheels fit on the back only, tried it and they BARELY fit..... fronts are too damn wide.. :willy:b_a_betterperson said:I've seen other people try to bolt Corvette wheels on GTOs. Doesn't work. The rear Corvette wheels don't fit at all. The fronts do -- but they stick out of the wheel wells by about an inch. Nice idea, though, just isn't feasible. Kinda wish the 5-spoke WS6 wheels from 2000 fit on the GTO as they look pretty good, too.
.....true, btw what's up with your avatar??djdub said:All of the above mentioned rims are the wrong bolt pattern, so offset is not the only issue.
It's a drawing of my new house that is being built as we speak. I pulled it from the builders website and changed the colors of it to match what it will really look like. It should be finished by the end of September.GTODEALER said:.....true, btw what's up with your avatar??
And no white picket fences.ftlfirefighter said:all it needs is a white picket fence!
Bad ass!!!! :cheersdjdub said:It's a drawing of my new house that is being built as we speak. I pulled it from the builders website and changed the colors of it to match what it will really look like. It should be finished by the end of September.
