I hear ya man...I'm going through the same thing
2004 GTO Black A4
Delivered weight 3868 lbs.
346 CID LS1
RWHP 289
RWTQ 292
Present weight 3227 lbs.
402 LS6 Forged Internals Stroker Motor Nitrous Express Wet Kit
Numbers to be finalized shortly
RWHP (NA) 561
RWTQ (NA) 604
RWHP 150 Shot 720
RWTQ 150 Shot 750
402 Stroker Motor Components
LQ9 Iron Block
Forged Balanced Eagle Crank
Mahle Pistons/Rings
Lunati Forged Rods
ARP Rod Bolts
Double Roller Timing Chain
SLP Underdrive Pulley
LS6 Ported High Flow Oil Pump
Comp Cam 238/242, .602 lift on a 114
Patriot LS2 Heads 64cc Chambers flow @ 330 cfm @.640 lift
Patriot Gold dual valve springs .650 lift
Titanium Retainers
ARP Head Bolts
Perma-Cool Remote Dual Oil Filters
Perma-Cool Oil Cooler
Shaner S3 Throttle Body
LSX Fast Intake
KN CAI
160* Tstat
Royal Purple Racing 41 Motor Oil w/ dual AC/Delco filters
Transmission 4L60E
TG Shift Kit
3500 Stall from Precision Industries
B&M Trannie Cooler
B&M Spin on Transmission filter
14 Quarts Amsoil Synthetic ATF
Driveline Components
3 ½” Extreme Performance Aluminum Driveshaft
Harrop Rear Diff Cover
SLP Poly Bushings
Koni Adjustable Shocks
Pedder Drag Springs
Nitto Drag Radials
Exhaust
Stainless Works Long Tube Headers
Gutted RT Cats
DynoMax 3” Tubes
Borla Exhaust
Only thing I didnt see on your list...ARP Rod Bolts....the stockers are lil bitty things....I built my stocker motor almost identical...and with a 100 shot put down 600RWTQ...rod bolts didnt like that and sent the rods through the block
