going to clean and condition the leather, the oil will be changed it's syn. so it don't go bad as fast. and I'm going to run the gas down to a quarter tank. then I will feed her raceing fuel in the spring to raise the octane. plus I will start it about 2-4 times a month.Since its coming up on winter and some of our cars are going away, I was wondering, for those of you who do store them, what do you do to store them.
:agree forgot to say the battery and cover and will be putting it on plywood to stop the dryrot.I would imagine fuel stabilizer,cover,unhook negative battery terminal,and maybe jack stands to get weight off springs if it will be in hibernation for 3 months or more.Indoors with a good cat to keep the varmits away.I will still drive mine with no salt or brine on roads,no snow,and above 0deg.
concrete sucks the moisture ot of any thing. you use to not be able to set a battery on the concrete because it would suck the charge out of it. with the new plastic we don't have to worry about that. but like said in speedwrenchx10 post would be best to get it off the springs as well. I just plain on working on it , plus it's abit hard to jack up.well i take off stock rims and tires off put 17' inch and crapy tires so tires the tires get messed. what does the plywood protect from dryroting
This is exactly what I've done with my cars when I was up north. When you start it, don't just let it run for a few minutes, let it run till it gets good and hot. you need to burn condensation out of the exhaust and the oil so plan on about 15 minutes. If you can do a once around the block or at least up and down the driveway that would be a good thing to do once a month.going to clean and condition the leather, the oil will be changed it's syn. so it don't go bad as fast. and I'm going to run the gas down to a quarter tank. then I will feed her raceing fuel in the spring to raise the octane. plus I will start it about 2-4 times a month.
:agree I'm shore the motors now a days are better and they wont stick up. but back in 91 I had a 350 2 bolt main in a 74 nova hatch back. I snaped the skirt on the #3 piston the wrist pin seized up, because I didn't start it all winter. so that bad luck has had me worried since then.I think the starting and driving are not that important if stored properly.I have owned boats for 15 years and used to fog the engine fill cooling system with rv antifreeze place the lower unit in full down position and never starting till the warmer months.I had no problems ever.I have not used fogging oil in 10 years and only stabilize fuel and drain fresh water.The thing still fires right up and runs strong as ever in the spring.IMO if its out of service for only winter no need to wake the beast from hibernation until your ready to play.Go play in the snow with atv or snowmobile.arty: :cheers
:confused That sucks if that happened to me I would start fogging everything again.I would never think that could happen in that short of time.Do ya think the Nova did it by itself to get more ponies in the spring.Damn Ill probably fog the boat this year.:cheers:agree I'm shore the motors now a days are better and they wont stick up. but back in 91 I had a 350 2 bolt main in a 74 nova hatch back. I snaped the skirt on the #3 piston the wrist pin seized up, because I didn't start it all winter. so that bad luck has had me worried since then.
:agree that car did do it, I bet. she did end up with flat top pistons and some 202 intakes. it was all a scam.:lol::confused That sucks if that happened to me I would start fogging everything again.I would never think that could happen in that short of time.Do ya think the Nova did it by itself to get more ponies in the spring.Damn Ill probably fog the boat this year.:cheers
I dated a girl in high school that had one that was red with white top I called it a sn*tch back if you know what I mean.I loved that car in many ways:agree that car did do it, I bet. she did end up with flat top pistons and some 202 intakes. it was all a scam.:lol:
:cheers good to see you. feel the same, last year we had about 2 weeks that you could of sworn it was spring. I'd like to se the same this year. oh ya I'm up in northern IL for eveybody eles.S**t...I didn't drive my Goat three days in a row last week, and I was about going nuts, so putting it in storage is out if the question for me. Besides, here in St. Louis, we usually get a day or two break every couple weeks throughout the winter. I'll be driving it during clear weather...just avoiding moisure, salt, and brine.
Gerry
:cheers :cheers been there and I was doing that. fun car, fun girls good times.I dated a girl in high school that had one that was red with white top I called it a sn*tch back if you know what I mean.I loved that car in many ways![]()
Yeah, there are days here I'm sure I'll be able to take her out, and the Bonnie is running strong (drove her today) and ready for duty. I just shudder to think if this were my only car. I'll have to try to take some pictures of the hills leading to my house. No way in hell I buy the story that the Goat does well in the snow. Maybe with studded tires and 500 lbs. of ballast in the trunk it would be acceptable, but I'd have to try that. On flat land, maybe, but not where I live.:cheers good to see you. feel the same, last year we had about 2 weeks that you could of sworn it was spring. I'd like to se the same this year. oh ya I'm up in northern IL for eveybody eles.
was rainning cats and dogs up here today, had to drive the car to the shop for the door ding ( witch came out great ) some kind of dent busters no paint. ether way on the way to the shop, she was all over the road even with the t/c on. could not even think how she would be in the snow, and will never find out.have a truck to do the dirty work. shes still fun. last year we had a big snow fall the end of winter, I'd be doing 50-55 in about 8" of snow with no problem. but I'm from buffalo NY we would get 24" in one day and not blink a eye.Yeah, there are days here I'm sure I'll be able to take her out, and the Bonnie is running strong (drove her today) and ready for duty. I just shudder to think if this were my only car. I'll have to try to take some pictures of the hills leading to my house. No way in hell I buy the story that the Goat does well in the snow. Maybe with studded tires and 500 lbs. of ballast in the trunk it would be acceptable, but I'd have to try that. On flat land, maybe, but not where I live.
Gerry
I have found not driving the GOAT for days in a row is difficult emotionaly but it is like free mods.It seems if I drive it too frequent I get used to the power.When there is a chance of wet weather I drive a 4cyl S-10 w/auto trans and if there are several nice days in a row I split them up by riding my motorcycle.This will be my first winter with the GTO sure it will be painful but mabey my atv may help.:willy:S**t...I didn't drive my Goat three days in a row last week, and I was about going nuts, so putting it in storage is out if the question for me. Besides, here in St. Louis, we usually get a day or two break every couple weeks throughout the winter. I'll be driving it during clear weather...just avoiding moisure, salt, and brine.
Gerry
