Hello - '67 GTO. Trying to identify and find the wire end terminals from a turn signal switch connector (pictured below). New to the group, so my apologies if I posted in the wrong place, but thanks in advance for your help.
David Poitras
136595
How many do you need? I needed one but had to buy a bunch. I would have to go back and research where I found them, but they are available.
I need at least 9, but don't mind having extra on hand. I'd be happy to buy a few from you or grateful to know the description and where you found them.
Thanks,
dp
So I only have 9 and want to keep a few so I can part with 6. Private message me with your address and I will send them.
I am am curious why you need 9. If you have good connectors in the larger connector assembly, they can be removed with the wire still connected and re-use it. I pulled all of them out of one of the fuse block connectors.
I purchased mine on eBay for about 14 dollars. Here is the description.
Vintage GM Chevy General Motors Twin Lock Bulkhead Connector Terminals
When I search using that description, I find the same thing I bought.
I completely misread your question. Which is why I should have been in bed instead of trying to answer questions at 1 in the morning.:sleep:
