Is it true that the LS2 throttle for the corvette and GTO is set at 88% max wot?
I have a 2005 GTO with a procharger. I posted my stats several months ago. I'm was getting 525rwhp and 460 lbs of torque. 510rwhp corrected.
Car didn't seem as quick lately (even thogh still running fine) and had another dyno done on it. It only came out to just over 400hp. Granted the heat in Northern Va has been in the low 90's with High humidity but I can't believe it.
The car stock is probably around 340rwhp.
My tuner initially used a unichip setup for the engine management since the were no packages out at the time. They thought they could fix the problem with the HP Tuner which has a tune for the LS2. they installed the HP and retuned the car. Virtually no change. Still in the low 400's. They checked the cats, CAI, not getting errors codes etc.. these guys are at a total loss.
Looking for any suggestions. The procharger seems to be working fine - 8lbs of boost.
Appreciate the help.
