I've unscrewed-
The three screws on the door upper frame.
single screw on the vent to door outer panel
and the lower adjusting stud & nut at the bottom of the door
(the main window is completely removed)
The vent window will not budge!
Am I being a wuss and should put a bit more effort into yanking it out?
I've seen other Fisher '66 bodies that have a couple of additional bolts above the upper hinge, but these doors don't have those showing on the outside. :confused:
Discussion Starter #5 (Edited)
I've looked it over and may need a mirror to see inside, because externally there are no more screws or bolts.
Are these internal pieces that disassemble from inside?
