1 - 20 of 23 Posts
here's what i am working on, was wondering if a hood tach mounted over the middle of drivers side would be too much in your opinion? I can get a non working unit for dirt cheap.
I like what you're doing, and I think the diver-side tach is a cool idea. Can you make it look "right" and still be visible without the steering wheel rim getting in the way?
am picking up non working unit next week, yes as i sit it would be just above wheel hump directly above turn signal indicator, hate the tach down over console, and i do not want to tear my dash apart to replace a pod (seems like a ton of work). also i have an "original" pad all ready done so if i use harnesses on gauges i could swap it out in a few minutes. plan on wrapping it all in thin pad and "pleather" so i should be able to just mold the hump in, nothing compared to the pods (pics on photobucket).
http://s1098.photobucket.com/albums/g372/instg8ter/1966 Tempest/
LMFAO Eric, don't tempt(est) me, I was looking at twin turbos last night, how many boost, fuel/air gauges can we fit in that. Certainly hope i don't need an altimeter, now on that beast your building you might, as i am sure if you can get it to hook it will lift the front end up. I picked up an original 68' hood tach today for 25.00, i'll post mock up when i get it in.
Discussion Starter #13
still waiting on mine, figure for 25.00 i can't go wrong, have an electrician who will take a look and if we can't get it going i will probably send to Precision Pontiac when i get a few (hundred) bucks put aside. seen one of the 67' ones (taller housing for first half of the year only) go for $610.00 last week. Trying to get alt/PS pump brackets together, always the little things that hold you up. Going with 73' set-up that matches engine year, my pump is the triangular style not the bottle style, figure i am way past correct at this point and i am not paying 150.00 for brackets.
Put it on the hood :) my favorite memories as a little girl were in my dad's 67, maroon with a black vynal top, power windows, bench seats, annndd.... a working hood tach, awesome
Discussion Starter #16
received the hood tach, housing is too long for the dash so looks like it will go on the hood, anyone have mounting measurements? am waiting on gauges for dash pad, oil pressure is backordered, got smoked (blackout) lenses, w/7 color display. I will be stretching the dash as soon as i get them in for a test fit
1 - 20 of 23 Posts
